HI Anat
wow...you just saved US$149!!
that's a pretty neat trick you got there. Perhaps you can upload the instructions. specs with pics on how to build one? Do post it to the database section....
Homemade motofocus
anat, thanks for the lead.anat wrote:other options: You can order it from http://www.ozitronics.com.
Hi Anat
This is some serious stuff you have put together. I am impressed.
Have a couple of questions.
Does it have a pass thru to accepts serial command from com port?
If so, can it response to Ascom or LX200 protocol?
I am looking out for a Robofocus, Could this be just as good if not better?
Regards
Matthew
Regards
Matthew
Matthew:
The driver accepts serial communication via a serial port (the protocol is provided in the manual) but not ASCOM protocol used for astronimical purposes.
If you want to have fine focus adjustment without vibration, the DIY motofocus will meet the requirements. If you need to have an absolute position control and backlash compensation, it is possible with the DIY motofocus but you need to write your own program to communicate with the driver via serial port.
Another option is to use an LX200 emulator with a DC motor (http://www.technoplus.nl/astro/lx200.htm to communicate using LX200 commands. I cannot comment on the Robofocus because of no experience. Hope this helps.
Anat
Anat
