1st try at Digital Cam Astrophotography ..
AGMI
Post by AGMI »
my 1st try at digital cam astrophotography. Took a video and extracted the best frames then stacked 12 frames . Did a realy heavy image processing
Here it is
Grievous
Post by Grievous »
Good work there.
Charlie
Not bad for your first shot... may be you should try the RegiStax to do the stacking:
http://aberrator.astronomy.net/registax/
PS: Please don't split your message into multiple consecutive post unless it is very long.
AGMI
Post by AGMI »
yes i did use registax and
sorry had a little trouble attaching the pic
That's strange?? Hmm... Why is there so many "border" at the edge of the image??
weixing wrote:Hi,
Manual stacking?
AGMI
Post by AGMI »
i cropped the images i wanted to stack ut they were all uneven. explains
