Hi'
I like to sell the below EP from Televue.
Looking at S$270.
Also can consider trading with
Pentax XL14mm
TV 11mm plossl
TV 25mm plossl
Any price difference either you pay me or I pay u (in case of Pentax EP)
Product Attributes:
68 Degrees Apparent Field of View
10 mm Eye Relief
1-1/4 Inches Eyepiece Format
15 mm Focal Length
Re:WTS Televue Panoptics 15mm
- Attachments
- pan15.jpg (16.63 KiB) Viewed 3054 times
- wucheeyiun
Look like you plan for the binoviewer way in advance buying 2 EP at one go. OK try to activate you earlier in next ob at Tuas.wucheeyiun wrote:David,
you should get one more 15mm panoptic instead...
sell the rest away...
BTW if we meet at tuas next time, you can try my pair of Antares 9mm orthorsopic, it sharp, bright and light. Got it from Sam.
After the lelong, I have both TV Pan 15 & Pentax XL14.So one of them got to go.Obviously I will keep the pentax and sell the pan 15mm.
DL
- wucheeyiun
The route of ortho's for bino-viewing is reasonably cheap, got to buy Antares instead of UO ( they are both the same and made in japan, but antares is cheaper ).
And also wide field we can use cheap and good 25mm plossls, in fact we can push up to 28mm i think( i did not try) some burgess lookalike ( c-type 22mm ca) binoviewer comes with 26mm plossl too.
actually there is an alternative now in the Orion Stratus line of eyepieces. Way cheaper than the Pentax XL. Seems to have pretty good review.MooEy wrote:wahahaha another pano 15, expensive wor. but another xl also expensive.
I just ordered a Stratus 17mm to fit in between my Pentax 14 XL and Pentax 21 XL. Will let you guys know how it performs compared to the Pentaxs. However, my scope is a f/10..so i think performance is close. I will go find a fast scope of around f/5-f/6 and try.....that would be quite a good test.
