Any one with this to sell?
To mate with Burgess Binoviewer, and / or 1.25" visual back, any comments or problems?
Also can mate with 1.25" diagonal.
PM me, or call chee yiun 93827727
WTB 1.25" focal reducer ( found)
- wucheeyiun
- wucheeyiun
The Celestron/Meade F6.3 Focal Reducer is screw behind the OTA and then you screw in your visual back or SCT diagonal on it. You don't need to take out the focal reducer when change from 2" to 1.25" or via visa... Also, a lot of C8 user just leave the focal reducer on and use it as a dust seal...Good idea, but the logistic of taking out and removing changing from 1.25" to 2" again, fumbling in the dark is tough...from planetary to rich field DSO...
Any any one with a 2" reducer to sell? i may consider...but 1.25" prefered.
- wucheeyiun
Just communicated with ACC, will bring in from US astrovid, when arrive Chee Chien and myself will play with it for a while, will let you know the effectiveness of a 1.25 reducer for binoviewer, if good will recommend to singastrorian. will also sub-sale
It could be screwed on to diagonal, or 1.25" sct visual back, or simply on the binoviewer,
David Lian, will you be interested? its only 49USD, can share UPS some-more
It is a rare item, only one post on the astromart ( dealer) , hope it is not a lemon.
http://www.astrovid.com/manufacturer_pr ... hp?man=236
At present moment, my priority goes to get the other EPs for
TV 11mm or 25mm plossl
I already got focus reducer to screw on SCT.
Once you try give review leh.
DL
