Forum upgrading to ver 2.0.17 done.
Stuff ironed out will be:
Changes since 2.0.16
* Added extra checks to the deletion code in privmsg.php
* Fixed XSS issue in IE using the url BBCode
* Fixed admin activation so that you must have administrator rights to activate accounts in this mode
* Fixed get_username returning wrong row for usernames beginning with numerics
* Pass username through phpbb_clean_username within validate_username function
* Fixed PHP error in message_die function
* Fixed incorrect generation of {postrow.SEARCH_IMG} tag in viewtopic.php
* Also fixed above issue in usercp_viewprofile.php
* Fixed incorrect setting of user_level on pending members if a group is granted moderator rights
* Fixed ordering of forums on admin_ug_auth.php to be consistant with other pages
* Correctly set username on posts when deleting a user from the admin panel
Yong Quan
