where to find geminids?
- soulfrost
- Location: cookieland, dreamworld, North east Singapore .
heard that there will be a shower on 14th dec. anyone know where to see? thanks alot in advance! ^-^
- Canopus Lim
The meteors will be radiant from the constellation of Gemini which is on the lower left of Orion. However, mostly spore cannot see meteors well due to the crappy skies. If you do want to watch, make sure that at least it is not overcast.. and look at cloud openings for meteors that are bright enough and lucky enough to pass through that small opening. I have seen meteors like that quite a lot of times in spore. And... you have to be patient.....
Guess the best time to view it will be around midnight that night in the direction of east, when the constellation Gemini will rise reasonably high enough to be visible enough.
But the only setback is that the shower will coincide with the Full Moon.
Anyway, look out for two bright stars (Castor & Pollux) side-by-side, halfway between the Moon and the eastern horizon. The outbrust (radian) of the meteor shower will be somewhere ard there.
Let's hope the sky is clear on the night!
- Attachments
- geminids.jpg (24.61 KiB) Viewed 7197 times
~Clear skies don't occur every night, so date your BIG LENS out when the chance comes~
- starfinder
- qu1xs1lv3r
