I'm kind of interested in getting a high power EP for planetary and finding DSOs like planetary nebs. Problem is, i have limited experiece in using 2 of the brands i favored currently: Pentax and Tak. Specifically, the XP3.8 and 7.5LE. Anyone tried both before? Will like your views on this. Thanks!
Charlie
I recommend the 5 and 7.5mm LEs (have them both). For that short focal length, they have reasonable eye-relief of 10mm plus excellent optics. With 5 elements, they are brighter than radians / XLs, important for faint planetary neb. The XP3.8 is particularly good for planets but eye relief a little tight. If you can bear with it its is probably even better than the LE almost everything else in the same focal length (naglers / radians etc).
my guess is pentax xl for no. 2 and televue panoptics / naglers / radians for 3,4, 6 and 7?? It is true that the many-element TVs introduce a yellowish / brownish tinge. I have noticed it in the T6 nagler, radian and very slightly in the panoptic (count the number of elements and u know why). The TV plossl on the other hand is very clean, but so are most other few-element eyepieces.
