Hi Singastroians.Hi Richard,
As a newbie, I would like to have some advices from you on the equipment. What would you suggest for a scope with mount and a bit of accessories that is less than $1000/- and is able to do astrophotography. Also, something a child can handle it for star gazing. I was thinking abt something 4" to 6" scope (mak type or =?) so that it will not be too long for my dry cabinet (DigiCabi AD100- int width 40cm). Will the Vixen VMC110L/Porta fit the needs or you will suggest others? I'm not ready that new to optic devices, I do handle cameras and microscopes for years except I'm new to telescope.
I was also looking for a binoc for star gazing. Most of the singastro guys would always suggest a 7x50 or 10x50 or smaller, but even at this lower mag and light, the binoc still "shake", may be I shake. I do have a 7-15x25, when it goes above 10x, it shake and it is difficult to watch the stars. So, I need one that has a tripod mount to eliminate the "shake". I know those big binocs come with tripod mount, can 10x50 be mounted on a tripod? If not, which bigger bincos will you suggest 15x70 or 20x80? In HK (Grand Eye), the Oberwerk 15x70 cost HKD499/- and I might be travelling there early next month and can get one.
Thank you and have a nice day
I received this query from an interested newbie.
As my expertise is not with astrophotgraphy, I thought I will put it up here
so astrophoto gurus can share their experiences here.
In answer to the question, for $1000, the range of available solutions is quite limited. You will need an equatorial mount (for series photography) or a dual forkmount goto scope (for light stuff like planets and the moon).
If bought brand new, I think it will cost at least slightly more than $1000 unless you put up a WTB post in the forum. Maybe someone has one you need collecting dust and want to let it go.
As for the cabinet, I have the exact same one and it just (barely) able to hold by Nexstar 8. I'm not sure about the scopes you mentioned as I do not own them. You can check with Robin from Mcgill.
actually 7x50 is quite a good solution if shaking is your problem. You need to get a better pair like the Minolta Classic or Activa series (sadly they are no longer in production), otherwise I guess your 7-10x will still make it. Many of these binos have a screw thread in front (normally covered) for an angle plate for installation to a tripod. I think some members here would be able to recommend them. Alternatively, with $$$ to burn, then go for the Canon stabilised binos. Also, I find the best way is the find a field, place a mat , lie down on a pillow and gaze from that position.
Oberwerk is a good brand and I think the best person who can give you advice is gavin (hope he is reading this!.)
And don't forget to join weixing at tampines during his sessions as he has a wealth of experience to share with regards to astrophotgraphy. he is quite high up in the learning curve now!
