FS: high quality dovetail/saddle plate package
denebman
Post by denebman »
I have few pieces of custom made dovetail/saddle plate packages to sale, they are CNC machined from an aerospace grade aluminium alloy that is much tougher than T 6061.
The dimention is: 4" X 8", thickness: 1/2", hole separation on saddle plate: 35mm pair and 76.2 mm pair (OD=8mm). The surface is anodized & sand blasted.
Price: $195 per set.
Please PM or contact me at 93626105 to test or buy.
denebman
Post by denebman »
An example to mount my homemade TMB115 refractor. The centre of gravity is easily adjusted when one switches between a massive 2" nagler ep and a 1.25" tiny tmb supermono.
sweet!
is the saddle plate compatible with losmandy d-series dovetails?
denebman
Post by denebman »
The set was made according to Losmandy's standard.
jermng
Post by jermng »
Hi Liu Ming,
What do you mean when you say the Centre of Gravity is easily adjusted? Is it adjusted with the saddle/dovetail connection or with the tube rings? (I've never used the Losmandy system before)
Thanks!
Jeremy Ng
C8, CR-150HD, TMB 80 f/6
Minolta Activa 12x50WA
The adjustment is done at the saddle/dovetail connection. :)
denebman
Post by denebman »
mrngbss wrote:The adjustment is done at the saddle/dovetail connection. :)
Yes, the dovetail plate can slide forward or backward to achieve the best balance of your OTA. And also, the spring loaded connection gives you a sure feel on whether the dovetail is secured or loosened.
Update: the last piece is reserved. thanks for viewing.
Congrats! and to all who own this :D
denebman
Post by denebman »
I am dropping the price to $ 150 to sell the last set. Thanks for viewing.
jermng
Post by jermng »
Wow! Great price .. too bad I've invested quite abit in Vixen style mounting ... This would be great for a larger scope.
Upz!! :)
Jeremy Ng
