Tube rings for C8
kochu
Tube rings for C8
Post by kochu »
Hi All ,
WTB a pair of tube rings suitable for 8 inch SCT. If available pls pm me or call 9368 9558
Kochu/18-11-06
kingkong
Post by kingkong »
i'm curious, why do you need the rings, instead of a dovetail bar, for e.g.?
Maybe he is unable to fit a dovetail bar on the SCT? My school has a C8 and had difficulty putting a dovetail bar on it.
New holes have to be drilled into the scope to fit the dovetail bar. Now it works flawlessly. :)
I think what kochu want is to use the tube-ring on his 8" SCT OTA from his LX90, so he can use a dovetail on it to mount on a EQ mount.
kochu
Tube ring
Post by kochu »
Thanks weixing. You are correct. I had a good pair of tube rings which I used to mount LX-90 OTA . I sold it and that was an impulsive mistake.
Drilling hole and using a 13 inch dovetail bar is another way. But it can be avoided if tube rings are available.
Kochu/18-11-06
Don't drill!!! the metal scraps will go inside the tube and you have to remove the corrector plate to take them out. Are you looking for expensive rings (i.e. Parallax type) or a cheap one (Orion). I think I have the latter lying around somewhere, I'll pm you if I can find it.
Arief
ariefm71 wrote:Don't drill!!! the metal scraps will go inside the tube and you have to remove the corrector plate to take them out. Are you looking for expensive rings (i.e. Parallax type) or a cheap one (Orion). I think I have the latter lying around somewhere, I'll pm you if I can find it.
Arief
Wow, you sure have a lot of stuff!! :D :D
kochu
C8 ota tube rings
Post by kochu »
Thanks Arif.
Orion type tube rings are good enough.
As for drilling I will not do any thing recklessly.
Awaiting your pm
Kochu/18-11-06
