My original raw images were a little noisy and not really in focus, but I just took the lot and did some processing with registax and here is what came out. Just to give an idea of the before-after differece y'know.
Before
After
Saturn before & after
- harlequin2902
Samuel Ng
hi sam,
mm...not much improvement in detail except that its brighter.
did you play with the wavelet adjustment?
if you refer to weixing's recommended tutorial site, you don't see any enhancement until AFTER the wavelet processing...
- harlequin2902
The attachment show my saturn "before" and "after". You should be able to see a very bright image after the stacking. The wavelet only make the detail more obvious, sharpen or enchance the detail... depend on your "taste"... You can also try to adjust the wavelet until the saturn look very artificial... it quite fun to see the what different setting can do, but I'm a little bit lazy to play with the setting...
