yanyewkay wrote:
NONE cross-compatible. eg: GSM and CDMA requires different decoding, FM and AM radios, TV and satellite, bluetooth, wifi, etc...
Most systems mentioned above travel very short distance, so can't reach space
Space or satellite comm x'mit in powerful microwave. The problem is coding method like E^2PRML, etc and modulation like PCM, etc which the alien whether more adv or otherwise may not match ours. The other thing is the signal path, just like a beam of light, did we hit the correct target. So, at the end may be NO comm with them.
Hi I a am a new member of Singastro forum I think it is worth it to send signals to this planet as it might contain aliens.
yah.. i was referring to coding and modulation schemes. :oops: sorry I wasn't clear on that.
