Green laser lost focus
wucheeyiun
Post by wucheeyiun »
I have a typical green laser which had lost focus after using for 6 months...
anyone knows how to adjust it back to pinpoint.... :oops:
yanyewkay
Post by yanyewkay »
most laser led that are sold in the market come in a sealed modules. looks similar to common red/green LED where it is manufactured and cast in 1 piece
There's basically nothing you can do about it, i suspect that the led module had cracked.
Canopus Lim
Post by Canopus Lim »
The green laser is actually a complicated laser pointer as there is no laser diode that produces green colour. It has a diode laser which is used to pump the crystal inside (if I am not wrong Nd:YAG) and from this crystal and cavity it generates 1064nm laser before frequency doubling to green colour. It loses focus probably because something was misaligned (lens or components inside) or the laser diode pump may have burned out.
I don't think there is anyway to align back the lenses as it is sealed and there are no screws to align the lens. It is essential that the lens used to collimate the laser beam is good and well aligned else the laser cannot 'go far'. Did you drop it?
aquillae
Post by aquillae »
it happened to mine too, and i never dropped it.
jeff
astro-cubicle :: www.astrojeff.com
yanyewkay
Post by yanyewkay »
mm.. you guys used long period of time at a go?
where did you buy it?
aquillae
Post by aquillae »
not really, but maybe pressed it too long by accident (when it was inside my pocket) :P
i got it from another fellow singastro-ian.
jeff
neoterryjoe
Favourite scope: c5
Post by neoterryjoe »
apparently, my green laser just lost focus too..was not used frequently and didnt drop it, yet.... *sob*. its not cheap(bought from a singastroian new, its the black one..). hmmm. its seems that quite a few singastroians have problems with green laser pointers...
wucheeyiun
neoterryjoe wrote:apparently, my green laser just lost focus too..was not used frequently and didnt drop it, yet.... *sob*. its not cheap(bought from a singastroian new, its the black one..). hmmm. its seems that quite a few singastroians have problems with green laser pointers...
i di not drop it, it just became like that too, i bought the black one from singastroian for $90...:(
Clifford60
Post by Clifford60 »
All laser LED has a life span, so yours likely has come to the end of life or may be the laser LED is of a lower grade or so called quality reject.
Canopus Lim
My green laser pointer so far is still working fine and gives a well aligned and powerful laser spot. :) But it cost much and I bought it from a reliable source.
