PM me for contact , meetup at Choa Chu Kang MRT
C) 45 degree prism $35
metal front and rear , center prism housing I cannot tell is thin metal or plastic from tapping sound
celestron 94112-A although not labeled under at bottom , came with C90 scope
1.25" , correct-image , 18mm clear aperture , no anti-reflection coating
stored in dry cabinet , used condition , 1 small dust speck inside
www.celestron.com/products/45-degree-er ... e-diagonal
D) 32mm plossl $22
purple coating 1.25" , no dustcap , came with celestron C90 scope although no brand marking on the eyepiece
used condition , stored in dry cabinet
F) celestron photo tripod #93606 $4
very suitable for 500 gram to 1 kg scope , easy height adjustment with geared center column
pan-tilt up/down/left/right with locking knobs , long handle , 1.6 kg
3 section 131cm to top
geared column 159cm to top
leg section width are 36mm , 32mm , 28mm , no damage to legs as I have been careful
have hotglue residue marks on leg hinges top where I tried to reinforce and later remove
the locking twist knob for quick attachment plate was modified by me with 12mm brass washer , A + B epoxy , hotglue
that knob is the weak point , when you put the tripod folded on floor/car must be careful don't crash on this part or don't anyhow pull it vertically up 5kg strength like kids
www.celestron.com/products/photographic ... deo-tripod
WTS : 32mm plossl , 45degree prism , photo tripod
- Favourite scope: maksutov
Last edited by Hardwarezone on Wed Mar 13, 2024 11:47 am, edited 14 times in total.
Re: WTS : small parts , vixen dovetail & saddle , 1.25" kellner , 45degree prism , photo tripod
no celestron label at bottom although bundled with celestron scope
1 small dust spec inside , barely visible in photo
D) 32mm plossl $22
during photo taking i forgot to put the center column spreader to lowest touching the rubber o-ring with widest leg spread
height measurement are correct
this is the lever weak spot which you cannot crash onto the floor or pull vertically with few KG strength
hotglue residue , from previous modification to make it more rigid , too ugly so scrape most of it away
D) 32mm plossl $22
Last edited by Hardwarezone on Wed Mar 13, 2024 11:47 am, edited 8 times in total.
Hi Hardwarezone
Can reserve for me item A and E
If Alfred don't go for item B ,I am interested also.
Upon confirming what items ,pls pm me phone nos and l will try to arrange for metup.
Thanks.
Thanks.
Re: WTS : small parts , 32mm plossl , 45degree prism , photo tripod
Mr Chia , can arrange meetup.
Hi Hardwarezone
Will call you. Thanks
