Problem logging in using Safari 3.0
Have some suggestions to improve the site? Let's discuss it here....Might do some tests here as well
NapTrandnep
Favourite scope: 87252758522
Problem logging in using Safari 3 0
Post by NapTrandnep »
Correct me if Im wrong, if you check the "remember me" box, as long as you are on the same puter, you shouldnt have to log in. Right?
I log in thru "messages", click the "remember me" box, then I can get on 1 more time without logging in again. If I log in other than messages, it loses my "new posts". Then I have to search forums for them.
Ill try clearing cookies, good job for the wife.
Re: Problem logging in using Safari 3.0
Hi
If you have set privacy settings to "on", then all your settings will be deleted on exit, including saved passwords. Maybe this is the issue.
