Where to buy heavy-duty push trolley?
Anyone knows where I could get a good quality heavy-duty trolley to ferry my scope around? I have one of those from hardware shop but the wheels couldn't take it after a few runs. Load approx. 20 kg.
Thanks!
kayheem
Post by kayheem »
What kind of scope are you pushing around? Where did you get the present trolley from? Hands DIY or similar 'wimpy' hardware shop?
Something like this is rated at 150kg:
http://www.masterjack.co.za/images/plat ... able_h.gif
This can be found at the bigger HDB hardware shops, Homely Hardware or around Serangoon area. There is 1 shop diagonally opp Mustafa's, along one of the small lanes.
Lee
Post by Lee »
Go to any good hardware shop and get those with normally a Yellow Base, from Japan with good quality wheel bearings. Cost around S$ 80-100 as compared against the China Made one at around S$35-50.
No problem with my 12" & accessories.
mine's toyogo at $30. Bought direct from warehouse in toa payoh. Have been using it many times to transport the G11, weights and accessories. > 20kg.
Photon Bucket
Mine is a 4-wheel trolley with plastic base from Prestar, made in Japan.
Max. payload is rated for 120kg, no sweat for the Astrosky 11" dob which weighs 30.5kg without accessories. I have used it for about 10 years already and it still works well. You can get it from many hardware shops for about $100.
Wow! Thanks! Now I'm spoilt for choice... [smilie=full.gif]
Prestar trolleys (newer versions) are best. No squeeky sounds and very smooth. King George avenue has many stores selling them. Look around and yyou can find the best bargain.
I recommend weixing....you can't get a more proven heavy duty "trolley" than him.... [smilie=uhuhuh.gif] [smilie=cool.gif]
Have you considered those push trolleys instead. They can take alot of weight but of course, the footprint is huge...
Very good smooth bearings. If squeaky, just add some grease/oil and it won't squeak anymore.
swat_pup6433
Post by swat_pup6433 »
oh mine .. the 120kg load trolley looks like the standard " SAF " issued.. codename "A186" a bliss for guys who needs to transport tonnes of materials ard.. we did put 8 dummy missiles each weighing ard 30kg on it.. no problem.~
