As you may have read, the Ioptron produced the mount for 5-70 deg lat. As I don't have a pier, I set the lat to 5 deg. Caution: For safety reason, [glow=red]do not attach counter weight [/glow]at this juncture.
Set Lat to 5 Deg
Next, I changed the location of the alignment peg on the tripod head to prevent the counter weight from hitting the legs.
Picture: Change Position of Alignment Peg
Picture: Align equatorial mount
Picture: Secure the Mount
Picture: Assembled Mount
Picture: Comfortably with William Optics FLT 132
Setting up the iEQ45 - 2. Set Lat and Secure the Mount
- yltansg
Re: Setting up the iEQ45 - 2. Set Lat and Secure the Mount
yltansg wrote:Hi,
Set Lat to 5 Deg
Set Lat to 5 Deg
- Mariner
Hi Alfred,
I've got the same mount except that the latitude groove have been machined to go down to 0 degree. The CW and shaft do not clear the tripod legs easily even though the mount has been reversed to hand between the legs. I have the half pier fixed on but because of the low clearance, I was unable to fix on the CWs at all.
Because of this unresolved issues, I have yet to bring out my 9.25" for first light. Would you have any suggestions to make the mount work?
Cheers.
Cheers.
OCULARHOLIC ANONYMOUS!!!
- yltansg
Hi Mariner,
I faced the same problem. So I cut an opening in the half pier and also made 2 more smaller diameter CWs.
Here are the pictures.
http://www.flickr.com/photos/31073495@N ... otostream/
Very nice! Thanks for sharing. Embedding your photos here:
- yltansg
Thanks Gary. Mariner - hope to hear about your first light with the 9.25" soon.
- Mariner
Thanks for the photos guys. The opened half pier was the same concept found for staroptics' option but rather than cutting, I'm opting for a custom wedge to push out the eq head to get more clearance. Hopefully will work.
- yltansg
Hi Mariner,
Both ways are workable. Wish you all the best in your innovation
Do remember to share with us your results.
Clear skies.
Alfred
Clear skies.
Alfred
