Many Astro Items To Clear!
PHOTO 9:
(Left column, top to bottom)
3 more items added...
46. Tani Ortho 18mm (made in Japan, same as UO Ortho) $50
47. Stellarvue Illum. Reticle Eyepiece 23mm (full-multicoated long eye-relief ep no longer sold as an item, illuminator sold separate)[new] $140
48. Rigel Pulse Guide illuminator (fits item 47) $60
Earlier items:
10. Vixen Lanthanum LV Zoom 8-24mm $220
 8. Televue Panoptic 22mm 2"/1.25" $350
 9. Vixen 0.965" Orthos Set (5,6,7,9,12,18mm) $330 for a set
Richard Low
Chris
Post by Chris »
About the orion 4.5, I also have another one at home. Is it possible to use 2 of them as bino viewer?
You meant bino-scope, I believe.
Yes, possible...theoretically.
However there are several technical challenges to overcome...I would not do it, and won't recommend it too.
If you really want a bino-scope, maybe I can offer you my Vixen BT-80MA....
Richard Low
Chris
Post by Chris »
ok... but no thanks. I am still saving up for an EQ6 >.<
More items added to 1st posting:
49. Pentax XW 7mm [SOLD]
50. Pentax XF 12mm [SOLD]
51. Televue Nagler 7mm Type 6 [SOLD]
52. Televue Radian 3mm [SOLD]
Richard Low
superiorstream
Post by superiorstream »
Hi,Richard
Can reserve the Pentax 12mm xf for me?Will call you later to discuss metup etc.Thanks.
wucheeyiun
Post by wucheeyiun »
UPZZZ for Richard Low...selling all his best stuff for others to enjoy ... :)
Someone need to grab the nagler 7mm t6 quick ... this is one of the best for mid to high power eyepiece. it is sharp and bright to edge and 82 degree FOV, nice for non tracking mount too...
Pentax XF12mm is reserved for Mr Chia.
Thanks Chee Yiun. Yes, Nagler 7mm T6 is a great eyepiece: small, compact and gives sharp high-contrast images to the widefield (82 deg.) edge even in fast f/5 scopes.
More stuff to add:
53. Vixen BT-80MA 80mm Bino-scope [SOLD]
54. Hercules 8" Fork Mount (good for Bino-Scope) [SOLD]
55. Water-resistant Hard Case for Vixen BT-80 Bino-Scope [SOLD]
Richard Low
New items added:
56. Takahashi 1.25" Prism Diagonal $120
57. Green Laser Pointer (2 nos, more than bright enough for astronomy) $60 each (new) [reserved 1 no.]
Richard Low
Clifford60
Post by Clifford60 »
You are selling so many of your collections, what are you planning to keep? :lol:
