| Author |
Message |
sanjayc
I am looking at buying a Dry Cabinet. From online posts, looks like digi cab and toyo living are good. Toyo living seems much better.
In digicab, whats difference between digital display models and digital humidity controlled models? which one is better? what are advantages / disadvantages of each?
Hows digihub for buying?
What are the safe places where I can buy Toyo living / digi cab cabinets at a reasonable price without quality compromise?
do I need an additional digital hygrometer?
My requirement is for storing 35 mm film slr and lens. I stay in chennai, where rh goes above 70 %
Thanks in Advance
Clifford60
DigiCabi AD model the RH control is analog, but with digital display. DHC, the RH control is digital, you set the value you want and it will control within 2%RH. Dry Cabi can control down to about 30%RH, for optics normal set ard 45% to 50%RH. You don't need another hygrometer, both AD and DHC models have in build RH and Temp meters (digital).
If you r in S'pore, you can contact DigiCabi (www.digihub.com.sg) directly, the price is as stated in their webpage. They can delivery the unit to yr loc in S'pore.
Personally, I find there price reasonable.
View next topic
View previous topic
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You can download files in this forum
