Lightly used. Very good condition with foam.
Internal dimension: 40cm x 32.5cm x 15cm
Keep your valuable astronomy accessories in mint-condition with this sturdy waterproof case.
High-impact, shockproof polypropylene exterior and heavy-duty latches with secure release tabs provide sealed protection from dust and moisture
Customizable pluck-foam interior lets you organize your accessories just the way you want them
Waterproof design will even float on water!
Features removable shoulder strap, pressure-release valve, and comfortable carrying handle
Give your treasured astronomy accessories the protection they deserve with the Large Orion Pro Pluck-Foam Waterproof Accessory Case. This extremely durable large case is made of high-impact polypropylene to keep your valuable eyepieces, Barlow lenses, filters, diagonals, astrophotography cameras and other astronomy goodies clean, organized and protected so they're ready for action on any clear night. The included pluck-foam insert lets you control how to organize and store your accessories inside, so you can arrange your gear just the way you like.
When closed, the Large Orion Pro Pluck-Foam Waterproof Accessory Case becomes completely sealed for protection from moisture and dust. Its rugged, shockproof construction will help protect accessories stored inside against accidental bumps. This waterproof case will even float on water!
The Large Orion Pro Pluck-Foam Waterproof Accessory Case features two heavy-duty latches with secure release tabs, a pre-drilled lock hole, a comfortable carrying handle, removable shoulder strap, and a convenient pressure release valve. This large-size case measures 20.2"x16.3"x7.8" externally, and has internal dimensions of 19.0"x13.9"x7.3" - plenty of room for a thorough assortment of stargazing supplies.
With a Large Orion Pro Accessory Case, it's easy to keep all your gear in mint-condition! For astronomy, telescope, celestron, skywatcher, Orion, ioptron, lenses, refractor, eyepieces, camera, ccd, etc. All the precious items you want to protect!
contact me at 9457 0145. Thank you!
WTS: Large Orion Pro Pluck-Foam Waterproof Accessory Case (SOLD)
- Bergkamp_
- Bergkamp_
Re: WTS: Large Orion Pro Pluck-Foam Waterproof Accessory Case $110
=) Looking for new owner
- Bergkamp_
Re: WTS: Large Orion Pro Pluck-Foam Waterproof Accessory Case $100
SOLD =)
