Closed
Re: WTS: (NEW!) 680x320x170mm Aluminum Carry Case w/Pluck Foam, Astromania SCT F6.3 Focal Reducer, 80mm Tube Ring Set
Updated to include SCT F6.3 Focal Reducer
Re: WTS: 50mm CCTV Lens (For guidescope & Widefield imaging), Meade F6.3 Focal Reducer (Reserved)
added 50mm guidescope for guidecams
Hi Mr Chee
Can reserve the 20mm lens at $20 for me? Will ph you later for metup. Thanks.
Hi sorry, I meant the 50mm lens. Thanks.
Re: WTS: 50mm CCTV Lens (Reserved), Meade F6.3 Focal Reducer (Reserved)
Hi
Messaging you at singastro. Pls read. Thanks.
Hi
Messaging you at singastro. Pls read. Thanks.just talk to you over the phone. Not messaging. Thanks.
Re: WTS: SCT-T Adapter, Celestron 6mm UWA Eyepiece
updated to include T-Adapter, 1.25" Diagonal & 6mm UWA EP
