Just was made aware of this: Ikea Brasa pedestal lamp
http://www.ikea.com/sg/en/catalog/products/80138414/
Available at Singapore branches for $79. It is a 45cm powder coated steel hemisphere.
If you've ever tried making a ball scope, you'll know that the ball itself is a major headache to source. This one is 18" diameter so should be good for a 12" to 14" mirror maximum.
DIY Ball Scope / "Portaball" alike
- orly_andico
Re: DIY Ball Scope / "Portaball" alike
Or use as a curry pot if the project fails :p
This is just 1 part though. Alot of work will need to be done. Since the Portaball, there has been alot of collapsible truss dobs like the one Junwei has, hence not too sure building a portaball is worth the effort. Maybe Chee Chien and Mooey can violently object to this observation?
- orly_andico
well one thing the Portaball-style telescopes can do very well is that they can be driven without using an equatorial table.. (see Trackball Telescope).
This is only a 17.7" diam. half-bowl, not the same design as the Portaball. For ATM design, I would not recommend it for anything bigger than say an 8" mirror, if you want a full range of movement.orly_andico wrote:Just was made aware of this: Ikea Brasa pedestal lamp
Richard Low
