Is Bigger Always Better?
MooEy
Post by MooEy »
dunno abt 50% rule. from what i know, one magnitude = 2.519x dimmer. and the eyes cannot tell the difference between half a magnitude.
so if i have my 3 inch(80mm) scope now, and i compare it to a 8inch(roughly 203mm) scope. i would take 203^2/80^2 and that is 6.44x more light gathering power for the 8inch sct. so i take 2.519^x = 6.44 i could work out how many magnitude more i can see. doing the maths i get an answer around 2, which means a 8inch scope can see 2 magnitude more than my 3 inch toy scope, quite a big leap.
so now if i have a 8inch scope, and i compare it to a 12.5inch dob, using the same steps as above, i would get a value of abt 1 magnitude. an increase of 4.5inch and i only get 1 magnitude more >.<
so whenever u see those advertisement, saying that this scope can gather 150% more light than the slighty smaller aperture scope in the same family, u can safely ignore that, since u would barely see any difference.
chris shaw
Post by chris shaw »
I think there WOULD be appreciable difference between the ETX 125 and LX200 7 inch Mak but I would have to wait until my order arrives to compare....
I would have ordered an 8 inch Mak but Meade doesn't make any and I wanted the GPS capability!
Chris
A magnitude seem small, but (base on Tycho Catalog projection) the number of star from magnitude +13.50 to +14.49 are around 29,457,184 and the number of star from magnitude +14.50 to +15.49 are around 85,689,537... Will miss quite a lot of star by only a magnitude... :)
Also, you will see more detail even the aperture difference are only a few inches (I think 1 inch won't make any practical difference, but a few will)... :)
harlequin2902
Post by harlequin2902 »
Well, one sure way of bringing out that "appreciable difference" in an instant would be to set up both your scopes side by side and have them point to a large and relatively rich globular cluster - at this time of the year, I think M22 is still available. Though you won't really see a huge difference in visual brightness of the cluster in the large vs small, at higher magnifications (100+ and beyond), you'll see that the larger scope will do a much better job at partially resolving some of the individual stars within the cluster, while all you see in the smaller scope is just a fuzzy patch of light.
Samuel Ng
