Forum upgrading in process now.
Stuff ironed out will be:
Changes since 2.0.13
* Hardened author and keyword search a bit to not allow very server intensive searches
* Fixed full path disclosure in bad word parsing
* Resetting complete userdata array in session code if authentication fails
* Fixed bug in moderator control panel where certain parameters could lead to an "error creating new session" sql error
* Fixed bug in session code where empty page ids could lead to an "error creating new session" sql error
* Fixed html handling in signatures if html is turned off globally
* Fixed install.php problem with PHP5 register_long_arrays option turned off
* Fixed potential issues with styling system
* Added correct class to login_body template file
* Removed file db/oracle.php from package
* Removed version number from message body page in /admin (if user is not an admin)
* Fixed case-sensitivity issues in postgres7.php
Forum upgrade done(16 April 2005)
.___.
{O,o} O'RLY?
/)__)
{O,o} O'RLY?
/)__)
