since i hardly use the scope, shall sell it for about $100.
optically it isnt as bad as departmental store scopes and if you like projects, you can remove the front glass (not coated so it affects the image) and the internal barlow to convert it into a wide field 76mm f4 reflector.
optics are clean and only slightly out of collimation (had been since i got it ).
comes with a 20mm huygen eyepiece and a 4mm ramsden eyepiece, all .965 and a barlow too(practically useless though).
WTS Celestron Firstscope 76TT [closed]
