wtb OCA ( 1.4x - 1.6x ) - found
- wucheeyiun
Looking for a 1.25" OCA for my binoviewer, or a GSO type 2" barlow where the lens cell can be taken out to be reconnected to a 2" diagonal...
- wucheeyiun
The mewlon 210 does not cater for the travel, i thought it was strange, but it is true...I took the whole mirror out of mewlon to clean ( you know it is a used mewlon from markus ludes), and sure enough the focusing screw and thumb is very heavy duty looking...and weigh a lot. The mirror itself is about 1inch thick and could be dielectric coated.
I think it is quite unfortunate if the travel is insufficient for your binoviewer; I wonder if other premium binoviewers may also have this problem.The mewlon 210 does not cater for the travel, i thought it was strange, but it is true...I took the whole mirror out of mewlon to clean
I would have preferred to minimise taking out the mirror for cleaning. Would it be possible for you to clean it with the mirror intact? Seems like others have done that.
- wucheeyiun
The dielectric coating only applies on a small (2inch aperture) and flat area, on the big elliptical mirror like mewlon 210 (220mm dia.), the stress induced by dielectric coating (<100 layers) may ruin and distort the mirror.wucheeyiun wrote:The mewlon 210 does not cater for the travel, i thought it was strange, but it is true...I took the whole mirror out of mewlon to clean ( you know it is a used mewlon from markus ludes), and sure enough the focusing screw and thumb is very heavy duty looking...and weigh a lot. The mirror itself is about 1inch thick and could be dielectric coated.
- wucheeyiun
