Skywatcher Evo 102mm Black Diamond Refractor Full Setup $1200 (Nego)
Pristine Skywatcher Evo 102 BD refractor imported from Italy.
Supported by Celestron CG4 Solid Steel Tripods with legs same as CG5.
Skywatcher AZ4 solid solid steel head mount
OTA: The refractor is a a double Achromatic refractor optical scheme 102 mm focal length f / 9.8 magnification max. 204 x anti-reflective treatment, rack 50.8 / 31.8 cm, weight 3.8 kg,
eyecup and accessories viewfinder 6 x 30 , Eyepieces diameter 31.8 mm, Super 25 mm (40 x) and Super 10 mm (100 x), diagonal with mirror 90 ° 50.8 with adapter 3 mm 1.8mm viewfinder 6x30
This entire setup comes in two solid carrying bags and this is better than Celestron XLT 102mm. Buying this locally with cost upwards of $1800.
I’m letting it go for $1200 (Slighty Nego)
WhatsApp me for more details: 91195556
Skywatcher Evo 102 Black Diamond Refractor with CG4 and AZ4
- Favourite scope: Skywatcher Black Diamond 100ED
- Attachments
- AEA2FED2-056F-4D2C-96C9-8099C79CA225.jpeg (129.52 KiB) Viewed 5525 times
- 6240F2C5-86E5-4435-A81B-F49892A53415.jpeg (300.43 KiB) Viewed 5525 times
- F484A430-436E-4975-8A31-F558F063EEEC.jpeg (202.8 KiB) Viewed 5525 times
- 88149FBC-9A14-44DB-8E11-37B81FDF1C59.jpeg (207.6 KiB) Viewed 5525 times
- 357AAE66-3CD7-4A21-A203-AE9375980465.jpeg (233.66 KiB) Viewed 5525 times
