1) Stellarvue F50 50 mm finderscope with Stellarvue rings 50-60 mm and base with 1/4 inch attachment hole. Comes with stock diagonal (helical focuser) and illuminated recticle eyepiece. Can double up as a spotting scope - have used Hyperion eyepieces with no issue. Finderscope is unused - older model but has been kept in dry cabinet. Clean optics for the scope and dust on the eyepiece. I lost the front lens cap. WITHDRAWN. Decided to keep it for own use as its a nice RACI finderscope.
Specs are found here which is the newer model but i should think the specs are the same : https://www.stellarvue.com/9x50-finder-scope-black/
2) Stellarvue pair of rings for 50 mm diameter scope with base (1/4 inch attachment ) $30/- SOLD
Pm contact for photos. Thanks for looking.
