i was told to get matching pair of eyepieces, at least those within the same batch. still thinking of getting a pair of radian 14mm since there's a promo on. but not sure if it would work well.
I'm interested in the MaxBright binoviewer as well but I've questions choosing the right accessories that I should choose to go along with it? Do I need the
Glasspath compensator if I'm using an 8" SCT with 2" WO diagonal?
Regarding binoviewer, SCT has a very broad range in Focusing. Barlowing ( glasspath ) may not be required, unless you are using a refractor.
You can check with Remus in the purchase of the Maxbright Binoviewer, his service is very good
Thanks for the advice. What would you recommend as the pair of eyepieces to go with the binoviewer? I'm interested in a set of low-powered wide-field eyepieces with about 60-70 FOV.
I would recommend WO swan 20mm, for economical no nonsense wide angle eyepieces in matched pair...
or simple 25mm plossl or orthoscopic eyepieces to start.
