The iEQ45 finally arrived in 2 packages on 22 Sep10. First box contains the tripod, counter weight, power adapter and cables. Second box contains the Equatorial Mount and 8406 controller.
[left]http://www.flickr.com/photos/31073495@N05/5020307524/[/left]
[left]http://www.flickr.com/photos/31073495@N05/5019694445/[/left]
[left]http://www.flickr.com/photos/31073495@N05/5020308238/[/left]
[left]http://www.flickr.com/photos/31073495@N05/5019694723/[/left]
Next I will cover the setting up.
Cheers
Alfred
My Experience in Setting up the iEQ45 - 1. Box Contents
- acc
- Administrator
Hi Alfred
Welcome to Singastro and thanks for sharing. I have fixed the urls below. If you would like to embed the actual photos in your post, you need to use the [img]path[/img] tags instead.
cc
image URLs here:
cc
image URLs here:
I don't like Flikr because its a little more cumbersome to port your image elsewhere. What you can do for the image to display here directly is to use the [img] switch that chee chien indicated and copy the image location between the tags. Then delete the extra characters behind until you reach the .jpg portion. That would enable the pictures to be displayed here directly. Unfortunately, I can't do it for you as you need to be logged in as owner to be able to do this.
Cheers
Cheers
iEQ45
Alfred,
we should get our heads together, I have had mine since the start of the month, and it is quite a nice mount. I got it auto-guiding for the first time last night, after a guider failure.
All went well, I like it.
- Attachments
- Single 600 second sub
- Helix-test02_Sing.jpg (53.75 KiB) Viewed 15107 times
Nice pic! Welcome to Singastro!
- cloud_cover
