Observing Jupiter
Re: Observing Jupiter
Check out this view of Jupiter GRS and Ganymede's shadow at about 7:45pm tonight.
Image Credit: WinJUPOS
Jupiter's Great "Red" Spot visible from about 5:00am tmr early morning Sat 24 Aug. The longer you can keep observing, the higher Jupiter will be in the sky, the closer the GRS will move towards its center (e.g. around 6:30am).
Good luck to all the overnight or early bird stargazers! :)
bornfree
Post by bornfree »
praying for clear morning... praying for clear morning....
Born to be Free
If you see only 3 instead of 4 moons of Jupiter early tmr morning 25 Aug from SG, do not panic! Ganymede went "hiding" behind Jupiter. :)
Jupiter's GRS in prime time position to be viewed/imaged tmr early morning!
GRS Transit 1 Sept 2013 @ 05:27am. (Source Sky&Tel javascript)
GRS transit tomorrow morning Tuesday 3 Sept 2013 at 7:06am (credit: Sky&Tel javascript)
Weather permitting, even at 6:30am when the sky is still relatively dark, GRS is positioned at about 1/3 into the disc of Jupiter.
Jupiter's GRS visible tomorrow early morning when Jupiter is high up in the sky - Fri 13 Sept. Best time to observe it at around 5:45am. (Credit: Sky&Tel)
Jupiter's GRS visible tomorrow early morning when Jupiter is high up in the sky - Fri 20 Sept. Best time to observe it at around 6:32am. (Credit: Sky&Tel)
Johndepro
Favourite scope: Powerseeker 127 EQ / Powerseeker 50 AZ
Post by Johndepro »
I have to go school tomorrow >:(
-_JOHNOOI_-
Shadow of Europa moving across Jupiter tomorrow early morning 21/9. From 3:36am - 6:11am.
Visible from Singapore from start to finish! Jupiter rises at 2:15am tomorrow.
GRS (transit 2:24am) should be visible off-centre when Jupiter is still low in the horizon. If the sky is still dark and clear enough by 7:00am and onwards, may be able to see the beginning of Io's shadow transit.
