Counterweights
kayheem
Post by kayheem »
You can try getting some dumbbell weights from a sports shop at Queensway or Bras Basah Book Centre. You do not need a locking screw if you can sandwich the required weights between 2 counterweights.
Robin Lee
Post by Robin Lee »
Kayheem, I've thought of this idea as well. Since we are going to have one counterweight first, the second has to have a locking bolt first. By the way, is it possible that unstability at the countweight shaft might happen? Let's say the sandwitched counterweight might push both the counterweights to and fro.
Clear skies,
Robin.
kayheem
Post by kayheem »
Kim Miau wrote:Let's say the sandwitched counterweight might push both the counterweights to and fro.
If they are sandwiched tightly and the weights above and below are tightened, I do not think they will be pushed around.
I think one of the member had done this before, but I think he "glue" it or something like that.
Anyway, I think it might still get push around by a bit even you sandwich them tightly... May be sandwich + velcro will be better.
swimaniac
Post by swimaniac »
I used to use bumb bell weights and velcro to keep them together.
I only had a conterweight then and I put the dumbbell weights on top of it. The velcro secured them well with very little movement.
Swim or Sink
Robin Lee
Post by Robin Lee »
Does the sport shop help people to custom make a dumbbell?
Clear skies,
Robin.
ChaosKnight
Post by ChaosKnight »
For ref
Cweight.pdf
(163.31 KiB) Downloaded 380 times
Robin Lee
Post by Robin Lee »
Thanks a lot man. Are you a dota player?
Clear skies,
Robin.
same here.... it is a novel idea to use gym weights as counterweights, especially when one could put them in between two conventional counterweights... i do that for a couple of 1.25KG gym weights (with enlarged central holes) in between two 7-lb Losmandy weights. even cheaper than custom weights!
Photon Bucket
