Counterweights
Robin Lee
Counterweights
Post by Robin Lee »
Do you think that the counterweights offered by the dealers are pricy? Does the workshop can do a great job in making a counterweight? I'm thinking not to get additional counterweight from Losmandy but look for one from the workshop. USD79 for a 21# counterweight sounds silly.
Clear skies,
Robin.
acc
Post by acc »
I never understood the pricing for those counterweights... :)
Re: Counterweights
Kim Miau wrote:Do you think that the counterweights offered by the dealers are pricy? Does the workshop can do a great job in making a counterweight? I'm thinking not to get additional counterweight from Losmandy but look for one from the workshop. USD79 for a 21# counterweight sounds silly.
If you have the dimensions, you can get a metal workshop to fabricate one for you...
cataclysm
Post by cataclysm »
Counterweights are just dead weights. Nothing fanciful about them, just machine them to your specifications, or a container filled with sands will do the job.
ditto...go fabricate! cheaper! and you can "customize" the design, colour, metal type, etc...
Photon Bucket
Robin Lee
Post by Robin Lee »
Remus, any detail? I am totally newbie to GEM. Haha..
Clear skies,
Robin.
you need to find a metal machining workshop in your area. Knowing where it is, prepare a drawing that will illustrate the counterweight design, complete with dimensions and any other necessary specifications. Usually mine are made using cast iron, which is cheap, but since it will rust, it is best to anodize/paint the weight.
Photon Bucket
Robin Lee
Post by Robin Lee »
Thanks for the info. I find that the locking mechanism is the most difficult part to design for the newbie like me. Do you have any idea?
Clear skies,
Robin.
perseid
Post by perseid »
Finding a block of metal for the counterweights is quite simple. You can find them at wholesale metal shop. However, it must be machined to fit into your counterweight bar. Different mounts have different diameter counterweight bar. So far, losmandy has the biggest diameter bar.
The locking mechanism is just an ordinary screw of M8 or larger. Some have nylon tip to prevent the weight from slipping down and scratching the bar. Other just have a metal rod that does the job (with minor scratching).
Are you looking of a counterweight to fit into a specific mount?
BTW, scrap metal are fetch quite high price now. A 21# scrap metal cost RM5-RM10 ringgit nowdays! If it is a good aluminum, it would costs over RM200!
Robin Lee
Post by Robin Lee »
Yup, I'm looking for a G-11 counterweight. I will try the local metal shop first. My friend's father has a stainless steel metal shop but I think that's too... Haha
Clear skies,
Robin.
