First try on Astrophotography.
wucheeyiun
Post by wucheeyiun »
Hi kimo, received your pms..
here is some material for all to read ...
http://astrosurf.com/buil/d70/ircut.htm
Ignore the d70 camera procedure, but the evaluation is applicable to you :)
kimo
Post by kimo »
Thanks wucheeyiun.
Robin Lee
Post by Robin Lee »
wucheeyiun wrote:Hi kimo, received your pms..
Thanks man. It's very informative.
Clear skies,
Robin.
kimo
did you replace the IR cut filter with something else?
I got a 300D really cheap ($120!) and ordered the AR-coated glass from Edmund Optics (they have a local branch in Singapore) and it cost $50.. almost half the DSLR!
but I have not yet opened up the 300D. Is it hard?
I want to put in the replacement glass so that AF capability is retained...
kimo
Post by kimo »
It’s not easy to remove the filter from the filter bracket. I realized that hard edge pressure could damage IR filter permanently. You can just takes off IR and Bracket together. Actually don’t need to replace with any things.
