Yes, i just updated it, it now come with Back Lash Compensation and Autoguiding...enabled.
Not sure about pec...
There is a new yellow bar at the bottom left hand corner of the starbook screen, anyone knows what is that for?
Vixen Sphinx Tracking
- wucheeyiun
I had a Sphinx two years ago. I was excited to hear that they had added the autoguider feature but in reality it worked really badly with my SBIG STV. The DEC backlash was so bad that the STV could not drive it. You can see it just by using the Starbook. Using the lowest motion setting, you can move the RA easily back and forth with no unacceptable backlash. But try that with the DEC. You will have to keep pressing it to no discernable effect, and then suddenly it jumps unpredictably.
Unless they have improved the DEC since I have owned it, I wouldn't recommend the Sphinx for autoguiding astrophotogrpahy.
One last point- if you take care to polar align properly, you should be able to do piggy back photos of the sky with the Sphinx- it's decent enough for that.
Ivan
Ivan
- wucheeyiun
Hi andrew,
New firmware for sphinx, built 31
http://www.vixen.co.jp/at/sb-up.htm
can help translate the Japanese...
thanks
thanks
Your manual is not english?? Anyway, you can download the english version manual (around 17MB) at: http://www.company7.com/vixen/mounts/sphinxsx.htmlYeah I know that, and my manual is a hardcopy.
But Arief is multi-talented...
