Blue Skies! Anyone out obbing?
- cloud_cover
Re: Blue Skies! Anyone out obbing?
setting up now...
spoke too early...kaomoo wrote:setting up now...
no vis after 2 hours
on the bright side, I got my autoguider up and running. Though I will need to find a M42 spacer to sync my guilder's eyepiece with the guilder camera....
Other than southern skies, the sky is clear now! At least naked eye visual mag +3.85.
- orly_andico
A week and a half ago I was at 400m in the Swiss Alps. And the sky was... incredible.
Sigh. Back to earth now.
- cloud_cover
Yeah, I went out with full equipment only to find a complete overcast. Grrr.....kaomoo wrote:spoke too early...kaomoo wrote:setting up now...
Doesn't your Nexguide already come with a spacer to parfocalize the eyepiece?
you meant 4000m right?orly_andico wrote:A week and a half ago I was at 400m in the Swiss Alps. And the sky was... incredible.![]()
I am using it with a Orion Flip Mirror, which made the guider FURTHER then the EP.cloud_cover wrote:Yeah, I went out with full equipment only to find a complete overcast. Grrr.....kaomoo wrote:spoke too early...kaomoo wrote:setting up now...
Also, the ST80 worked very well with the Baader Hyperion ClickZoom....
- cloud_cover
Erm, reverse the guider and EP position?
Other alternative is simply don't use the flip mirror. Once you have centered your guide star you can just plonk the guider in. Given your guidescope is fairly widefield, it should be able to see a decent guidestar for almost any target anyway
u can't reversed, well.. you can i guess, since the auoguider can be configure with flip RA or DEC axis. easier to just pop a spacer in :pcloud_cover wrote:Erm, reverse the guider and EP position?![]()
i am under the impression that the high the mag the more accurate the guiding?
