Modified to Deep Cooled CCD camera
kimo
Post by kimo »
I just Modified DSI Pro into Deep Cooled CCD camera as a curiosity / Fun and to learn.
The CCD Box containing DSI PRO (circuit board only), Peltier device, Humidity sensor, Thermometer sensor, Metal bar for CCD and Drying Agent. I will show the camera very soon.
External devices:
1: Digital temperature controller.
2: Humidity and thermometer device.
3: Extra power supply
Dark frames were taken with this CCD. Ambient temperature was 30.6deg. I don’t know if it is worth for Singapore SKY ha..ha.
Thanks.
1min 30.6Deg
1min 20Deg
1min 15deg
1min 8 deg
1min 4deg
2min 4 deg
cloud_cover
Re: Modified to Deep Cooled CCD camera
Post by cloud_cover »
It is! You can now go after planetary nebulae with a long focal length scope and narrowband filters! Most planetaries are small, not needing a large sensor unless you have such a long scope.
roma_my
Post by roma_my »
Able to post the image of the modification process? Thanks.
roma_my
kimo
Post by kimo »
I took some images.
kimo
Post by kimo »
Today, I took Moon sample pic with this CCD cam, Sky is very cloudy at this moment . The ambian Temp was 29.3C, camera temp set to -2Deg cel below 0Deg C. I wanted to enshure that there is no Air Contamination. Telescope is 80mm refractor. It is a single Raw pic, no process was done. Focus were not very good as i used hand focus.
Thanks.
