Hi, I'm a beginner, looking for a pair of binoculars.
Anyone has an extra pair and want to sell at reasonable price?
Thanks
WTB bino
Re: WTB bino
Hi hazelwong. Welcome to the forum and the hobby!
The price range and physical size of a binocular can be quite wide depending on the brand/quality. Perhaps you may want to state your rough budget for this binocular.
While waiting for offers, do enjoy reading the forum content and borrow some books from the library about binocular astronomy.
Good luck!
Good luck!
Re: WTB bino
Hi, thanks.Gary wrote:Hi hazelwong. Welcome to the forum and the hobby!
Good luck!
I am looking for something that would alow me to see planets eg Saturn, moon surface, as well as nature (birds etc). would a 10x50 bino be ok? any brand ok?
thanks
- Mariner
Re: WTB bino
Not to poor cold water but you need to lower your expectations somewhat. A pair of binoculars will indeed show you planets like Jupiter or Saturn but will not show much details. The best bet would be to see the Galilean moons. You will not be able to make out much of Saturn's rings. On the other hand, the moon will be excellant.
The "standard" will be the 10x50mm binoculars. Anything bigger and it will not be pleasant to hold (unless you use it mounted). As for brands, I can't make any recommendations since I haven't used many and cannot attest to their quality. My personal set is a pair of Fujinons purchased over a decade ago.
OCULARHOLIC ANONYMOUS!!!
Re: WTB bino
hi thanksMariner wrote:Not to poor cold water but you need to lower your expectations somewhat. A pair of binoculars will indeed show you planets like Jupiter or Saturn but will not show much details. The best bet would be to see the Galilean moons. You will not be able to make out much of Saturn's rings. On the other hand, the moon will be excellant.
so to see Saturn's rings we need a telescope?
aperture 70 or greater?
thanks
Re: WTB bino
Hi hazel
Many years back I used my 50mm and it gave me saturn and its ring, jupiter and cloud bands, crescent venus etc etc.....
Perhap if you are very serious into this hobby and would like to get deeper into it then I would suggest you to get a bigger aperture you can afford. But of you have limited budget you might want to hold abit for people selling here, there might be good deals at times.
On other hand you can get sky watcher heritage reflector which comes cheaper and good....
Re: WTB bino
Hi, thanks v muchggodetucsamoht wrote:Hi hazel
the 50mm u used was a telescope?
About the reflector-- i'm a bit worried about the stuff on collimation etc. Would prefer something really easy to use. Maybe a refractor?
Re: WTB bino
The 50mm Mainer mentioned should be a refractor telescope since your previous question is about a telescope 70mm or greater. For a few seconds while reading his reply, I also thought he was referring to a 50mm binocular which is so amazing that can see Saturn rings.hazelwong wrote:Hi, thanks v muchggodetucsamoht wrote:Hi hazel
For a 50mm refractor, it is possible to change the magnification by changing the eyepieces. But you can't do that for most binoculars.
There is no perfect telescope. You should spend a bit more time learning about the pros and cons of each design, their cost, what kind of celestial objects you prefer to observe first and your budget. Else. you will go round and round and suffer analysis paralysis.
For example, in this case. If you don't mind spending some time to learn newtonian collimation, you will get the maximum value for your dollar in terms of aperture (diameter of primary lens/mirror) compared to a refractor costing the same. A bigger aperture will collect more light and let you see objects brighter, in higher resolution and allows higher useable magnifications. Of course, there are cons of the newtonian design like coma, viewing comfort and "hassle" of collimation compared to a refractor.
There are many free resources online explaining the collimation process (e.g. youtube tutorials). So it may not be that scary as you might have imagined it. Buying/upgrade newtonians with good collimation knob design can also lessen this "fear" and "hassle", e.g. the Heritage 130p has large knobs at the bottom for collimation. Collimation devices can be as simple and cheap as DIY collimation cap made of out film canister. Some newtonians are also designed to hold collimation well so you may not need to collimate it every single time you want to use it. Meeting up with members of this forum to learn collimation from them is also another good way.
Do take note to compare the telescopes at about the same price or within your budget. Especially when comparing the pros and cons. Else, there is always a better telescope for a "bit" more money and you may end up buying a Hubble Telescope.
If you have not done so, do visit as many free public stargazing session in Singapore and learn more about different telescope designs from the telescope volunteers:
http://www.astro.sg/2013/01/public-star ... apore.html
In addition to the resources in this forum, you may find this article and its links useful:
http://www.astro.sg/p/buying-telescope.html
There is also no harm in starting astronomy with a binocular first and enjoy its advantages. When you confident enough to invest in a telescope, you can then get one and enjoy the views of Saturn and many other celestial objects for many years to come.
Good luck and fun exploring the Universe!
Re: WTB bino
Hi HazelWong,
I m a SCT user and I do not have a Newtonian at home. And I can fairly say to collimate a Newtonian is rather easy. I managed to setup and collimate a 10” Newtonian during the last TPY library session while Gary was having his talk. Before hand I did not have much hands on experience on Newtonian and it's collimation. All you need to know some basic stuff (you can seach video's on youtube) and a Newtonian will be collimated in no time.Gary wrote:hazelwong wrote:ggodetucsamoht wrote: For example, in this case. If you don't mind spending some time to learn newtonian collimation, you will get the maximum value for your dollar in terms of aperture (diameter of primary lens/mirror) compared to a refractor costing the same. A bigger aperture will collect more light and let you see objects brighter, in higher resolution and allows higher useable magnifications. Of course, there are cons of the newtonian design like coma, viewing comfort and "hassle" of collimation compared to a refractor.
- antares2063
- Favourite scope: Newtonians
Re: WTB bino
Hi Hazel,
Personally I own a 10x50 binos that lasted me all this years I use it to "starhop" or to navigate myself around the stars in a dark site. If you are keen to do some basic observing, I can let you try the binos . (weather dependant).
Also gary very often holds his sidewalk astronomy session infront of Toa Payoh library, you can get to see the appearance and look through scopes and binos if there are. rlow (Richard) holds his sidewalk event along orchard rd cineleisure.
Skies look good today (as of 11am )
Junwei
Junwei
