Hi.. experts out there.. i hav a question abt the moon.
Yesterday night (21/08/04) abt 11pm.. i saw a waning moon.. tis is a veri special moon which i nver seen b4.. tis waning moon is orange-red in colour and the size is 2 times the moon that i everyday's moon.. is it that the moon is closer to earth? but y is it orange-red colour.. tnkZ
Desmond
question abt moon
yeah
anat is correct
the enlarged size is an illusion because your brain compares it with closer stuff like buildings.
the red colour of the moon is similar to a red sunrise, when a celestial object is low, the light passes through more atmosphere and red light is dispersed hence making the object look red. its true for all objects, moon, sun, stars and even planets. earthshine or the illum part of the moon, the same concept applies
anat is correct
If i'm not wrong, when a celestial objects is low down the horizon, the thick atmosphere tends to act like a magnifying glass (refraction of light), therefore any object, including our moon, will appears to be enlarged when its near the horizon. This also explain why we see the constellation Orion (and our Sun) larger when its near the horizon.
Sam
Sam
If it did, I doubt it magnify that much to be significant. The moon appears larger due to it being compared with objects in the horizon such as flats, trees, etc. One way to be sure is if you see the moon at the horizon, lock on to its size and imagine the same moon now at zenith. you'll be surprised to note that the size apparently looks the same!Sam Lee wrote:If i'm not wrong, when a celestial objects is low down the horizon, the thick atmosphere tends to act like a magnifying glass (refraction of light), therefore any object, including our moon, will appears to be enlarged when its near the horizon. This also explain why we see the constellation Orion (and our Sun) larger when its near the horizon.
Sam
perspective la, our eyes is like a wide angle lens, it distorts perspective. hold a piece of card near ur eye and look at an object far away from u, the card looks way bigger than that object. now move that card slowly away from ur eyes, it will start to look smaller and smaller.
the human is incapable of measuring size, often we just compare an object to another to tell the size. the moon is extremely far away from us, and if u use buildings or other things to compare the size, perspective will come in. if u stand closer to a building, the moon will appear smaller, but if u stand further away, the moon will appear slighty bigger.
a more accurate way of estimating the size of the moon would be extending ur arm straight, then use ur hand, see how many fingers it takes.
By the way, your last finger will cover 0.5 degree of the sky at an arm distance.
You didn't see wrongly... The moon was around zenith at 3pm yesterday.i saw the moon near zenith at 3pm yesterday...
or did i see wrongly?
I tell you what, do as Mooey mention, extending your arm straight and use your last finger (or the small finger) to cover the moon. Do the same when the moon is lower on the horizon. You should discover that the size of the moon is actually the same... your last finger will just cover the moon no matter where the moon is, Zenith or Horizon.the moon looks larger at zenith than near the horizon as it is nearer to us at zenith and further away (by 1 earth radius) near the horizon...?
