How to Converting RA-DEC to ALT-AZ for singapore
how to Convert RA-DEC to Alt-AZ
Hi Micheal,
this is the website I was talking about: http://home.att.net/~srschmitt/script_c ... rce%20code
The formula can be easily copied from the java code.
Will post more as I figure out more.
Cheers,
Chris
Cheers,
Chris
I need some help.. forgot my math..
when I cosine a number, shouldn't I get back the number if I inverse or arc cosine it?
Cos(A)=B; ACos(B)= A ?
so for example, cos(60)=0.5, acos(0.5)=60
but for certain numbers such as 282 degrees, the calculation doesn't work. Cos(282)=0.207, ACos(0.207)=78
Can someone explain and tell me how to get the arc cosine of a certain number in degrees? This is relevant in my conversion of alt/az to dec/ra.
Thanks,
Chris
Thanks,
Chris
hmm.. gotta use the quadrant rule.. as in
Sin(A)=B
1st and 2nd quadrant for sin rule meant for positive values of B
3rd and 4th quadrant for sin rule meant for negative values of B
Cos(A)=B
1st and 4th quadrant for cos rule meant for positive values of B
2nd and 3rd quadrant for cos rule meant for negative values of B
Tan(A)=B
1st and 3rd quadrant for tan rule meant for positive values of B
2nd and 4th quadrant for tan rule meant for negative values of B
so let's take for example
tan( angle x ) = 0.8
angle x = 38.65 or 180 + 38.65 = 38.7 or 218.6 degrees ( 1dp)
but if , tan (angle x ) = -0.8
angle x = 180 - 38.65 or 360- 38.65 = 141.4 or 321.4 ( 1 dp)
hope this helps
cheers,
wenyi
Sin(A)=B
Cos(A)=B
Tan(A)=B
hope this helps
cheers,
wenyi
