Tripod Vibration - Weights or shock mount?
Hi all,
As expected, my new tripod does vibrate alot and takes too long to settle down which is consistent with what reviewers have been saying. The time and tested method is to suspect some weight in the middle. But as I am not keen to add weight to the already loaded tripod, I am considering buying shock mount pads for the tripod legs. Does anyone have any experience with their performance?
Thank You in advance! :)
Hardwarezone
Favourite scope: maksutov
Re: Tripod Vibration - Weights or shock mount?
Post by Hardwarezone »
The "no brand" VSPs did work when my steel tripod legs were extended to maximum height. Tap the OTA can reduce vibration by half.
Been using it seated with tripod legs retracted so the VSP are kept in storage since. It doesn't have any positive effect when legs are 0 to 50% extension.
Aluminum legs I dunno , seen some cloudynights people build a big plywood triangle as a better spreader.
Thanks...! Looks like I need to take alook at shock mounts then... :)
Hardwarezone
ebay.com.sg have those no-brand VSP at $22 only
search "telescope vibration"
then left side tick the box "worldwide sellers"
Thanks for sharing, Bro. :)
Bialek
Post by Bialek »
That's an awesome solution tbh. I'm going to try this out too. Did you end up buying this, Airconvent?
Hi Bialek,
Sorry, missed your post because it did not end up in my "new post list".
No I did not buy the new one as I am trying to see how to best use my Porta II instead. :)
