I think I accidentally kick the tripod :oops: , so the tracking is off. To reduce the star trails (Packing up, so no time and too lazy to redo polar alignment), so I used ISO 1600... a bad choice... won't do that again next time.
Anyway, after compare all my images to those produce by our expert here (TG, Matthew, JY, Kochu & etc), I think all my images appear more blueish and most of my red components are lost.... I think due to the way I do noise reduction in photoshop... will try a different approach or software.
Good.I see that you got a new 300 D. New CNY purchase?
Shot has come out well. Don't bother about the back ground stars much. Keep up the good work.
BTW ISO 1600 is not a bad choice as you seem to think.I think it is quite tolerable with 300 D
The lack of red component will be there till you take the bold step of modifying the 300 D.
I won't do that modification (remove the IR filter), since I'll be using it for normal photography. Heard that you won't be able to get an accurate auto-focusing and white balance after you remove it even you put an external IR filter.
weixing wrote: I won't do that modification (remove the IR filter), since I'll be using it for normal photography. Heard that you won't be able to get an accurate auto-focusing and white balance after you remove it even you put an external IR filter. Have a nice day.
Well then, there's a good excuse now for you to get your hands on the new Canon 20Da
