Today late afternoon as I was cleaning my scope exterior, I accidentally brush over part of the corrector plate of my MCT. To my surprise, the part of corrector plate that the brush touch show a sticky substance. I'm sure that the substance is not from my camera brush.
After checking with a red touch light, I found out that the sticky substance was part of a thin layer on the corrector plate which I discover when I got the scope and it seem not causing any image degrade, so I leave it alone(I thought it was the imperfection of the corrector plate glass, because it was not obvious at all, you need to face the corrector to a light source and look at an angle to see it).
Anyway, I use my LenPen to generally clean off the sticky portion as much as possible(it getting late and not enough illumination). I test the telescope tonight(19 Oct) and discover that my scope can now focus even more sharply... may be also tonight sky was very clear.... I plan to get a new LenPen tomorrow and do a thorough check and cleaning if needed...
By the way, do any of you guys have this on your corrector/lens??? My initial conclusion is that this layer is cause by the water vapor in the air that trap the dust and "stick" to my corrector plate when I was doing observation.
