Interesting solar facts in the middle of this video
superiorstream
Post by superiorstream »
Hi All
I want to bring your attention to the middle portion of this video in Utube.....
The Great global warming swindle.
Where they explain the global warming is actually due to the sun.
Actually there are global warming and cooling of the earth by professor chu kochen(also called zhu kechun)
in his research articles between 1964 to1972? that deal with the average temperature of China for the past
5000 years.....yes the past 5000 years.......using flowering ,animal appearance ,historical records etc.
And these AVERAGE TEMPERATURE CURVE....called chu kochen curves were found to match with those found
in using ice core samples in the polar regions.
On Utube the video is also available as........geography of china.....hundred year great discovery...ask heaven hot or cold(in chinese of course).
It should be noted that this clearly illustrate that global warming and cooling is cyclical and vary plus minus about 2 degree C about a mean temperature.
Secondly for the past 100 years the temperature is on average in the rising trend. Presently we are about 0.5 degree above that average.
Thirdly the last prolong peak is during the tang dynasty which last almost the period of the tang dynasty.
Fourly such elevated temperature enhance agriculture production due to more rain during such temperature elevation.
But the most interesting part is it make solar observation worthwhile.....to be continued.
superiorstream
Re: Interesting solar facts in the middle of this video
...continue.....
And its interesting to note that the last solar cycle starts late,ends early,and has a lower peak.Also measurements of solar surface vibrations etc suggests that the sun may be heading into another maunder period.Well if you look at the cho kochen curves those hot and cold oscillations has period of hundred
to few hundred years.Also the most recent ice age sets off about after the maunder cycle and so does the temperature and earth increase in carbon dioxide.There is also a obvious lag in timing.Also agriculture produce are better during hot period....like during the tang dynasty.....that the cold period which oversee the collapse of dynasty.
Whatever it is......this makes solar observation interesting.
We seem to be at a dividing pt.
Is the solar cycle going to restarts. If it starts it seems that global warming is going to continue.
But if the maunder cycle sets in then if ths sun is responsible for global warming then earth AVERAGE TEMPERATURE will starts to fall in spite of carbon emission increasing in about the most 50 years time.....the observed time lag during the last maunder cycle...... perhaps due to stored heat?.
Already the changes in AVERAGE TEMPERATURE is well established in china showing itself as total destruction of forest in canton,tropical species found
it high latitude in China,destruction of rising civilisation in northern as far back as 8000.....yes 8000 years ago etc.All confirms the correctness of the
Cho kochen curve......the only regret is that solar sunspot is just 400 plus.
But even then the match for those periods are pretty good.
SO FINALLY LETS LOOK AT THE SUN FOR ANSWERS AND ITS NOT GOING TO BE LONG.WE NEED A NEW MAUNDER CYCLE FOR VERIFICATION.
WARNING..... A dip in temperature....global cooling I believe will bring about food storages as verified in those records in China.
Thanks for reading.
superiorstream
By the way
The only place you can find a bit of cho kochen material(articles) is the science and technology llibrary in NTU....old article in the 1960s.
At ntu and national library I was not able to find materials related to that AND
do notice that the western world is either ignorance to cho work or completely ignore his important contribution.
In another exploration into such warming and cooling its comforting to learning that the earth had gone through 32 mini ice age......some longer and some shorter(in China)in the past 2.5 million years(in china).
So no worries.
And continue to look at the sun for warnings.
superiorstream
It should be noted that according to cho kochen curve the average temperature is 2 degree C ABOVE the average during the tang dynasty and now we are about 0.5 degree above the average.So no worries about those frightening worries about food shortages etc. In fact the tang dynasty turns out to be an age of plenty and those times when the AVERAGE TEMPERATURE dip by 2 degrees below the average turn out to be mean years causing food production to drop significantly. In fact dynsty collapse occur during those periods.Things seem to be better during the hot periods. Of course sea level will rise,more rainfall,iceberg will melt,and wind causing disasters will be worse during hot periods....but if the çause is the sun then all we can do is take all precautions. Of course the most important is look towards the sun for forthcoming events and this is even more true in todays world. A Carrington event will bring disaster to the world and shut down all electricity supply worldwide.
AdamWitty
Post by AdamWitty »
superiorstream wrote: Mon Dec 24, 2018 9:59 am It should be noted that according to cho kochen curve the average temperature is 2 degree C ABOVE the average during the tang dynasty and now we are about 0.5 degree above the average.So no worries about those frightening worries about food shortages etc. In fact the tang dynasty turns out to be an age of plenty and those times when the AVERAGE TEMPERATURE dip by 2 degrees below the average turn out to be mean years causing food production to drop significantly. In fact dynsty collapse occur during those periods.Things seem to be better during the hot periods. Of course sea level will rise,more rainfall,iceberg will melt,and wind causing disasters will be worse during hot periods....but if the çause is the sun then all we can do is take all precautions. Of course the most important is look towards the sun for forthcoming events and this is even more true in todays world. A Carrington event will bring disaster to the world and shut down all electricity supply worldwide.
Hi everyone! I have recently joined the forum just reading the knowledgeable stuff from this forum . Thanks for sharing the information . :D
