light pollution!
oxygn
light pollution!
Post by oxygn »
hi guys,
how do we reduce or even get rid of horrid light pollution in the photo?? photoshop editing or have to use LPR??
Thanks,
Colin
ISO 1600
30 sec - F/5.6
D70
light polution picture
a lower ISO may help
oxygn
Post by oxygn »
thanks Arief. so am i right to say that if i use a lower iso, i would need a longer exposure time to collect the same amount of light that a higher iso would in a shorter time but the advantage is that i would not get too much skyglow in my pic?
Thanks,
Colin
The lower ISO will not reduce sky glow. Use a LPR Filter to reduce the sky glow will be a better choice.
tanguan2001
Post by tanguan2001 »
I use an LPR filter, which helps a lot. The other thing I have noticed is that at around midnight the level goes down quite a bit. So I now image mainly past midnight - but I miss my sleep!
TG
oxygn
Post by oxygn »
hey all,
thanks for all your replies. if i'm shooting thru the the camera lens instead of the telescope, how do i use a lpr filter with that?
what kind of lpr is recommended?the ones that attached to the eyepiece or the ones that attached to the back of the scope(which cost more i think)?? are there anymore types?
and which brand of lpr filters would you guys recommend?
thanks again,
Colin
tanguan2001
Colin,
I use the Celestron LPR which fits to the rear cell of my C9.25. It's very good quality - no ghost reflections, provided used before the Focal Reducer.
One way of using an LPR with camera lens would be to get a 2" mounted one, and the appropriate step ring for the front of your lens.
Thinking of doing just that with my H alpha filter.
TG
MooEy
Post by MooEy »
they do have lpr filters bigger than 48mm, prolly all the way up to 82mm. but those are very very expensive.
http://www.sciencecenter.net/hutech/filtlist.htm
oxygn
Post by oxygn »
tanguan2001 wrote:Colin,
TG
hey Tan Guan
is the 2" mounted one is the one that fits onto 2" eyepieces issit? the largest step ring seems to be 58mm. my lens is 67mm. anymore solutions?
Thanks again,
Colin
oxygn
Post by oxygn »
Hey Tan Guan
what does modifying your canon 300d do? does it improve the sensitivity to near IR range?? wouldn't i get a somewhat effect if i put an IR filter to let IR pass only, then i combine this frame with the visible spectrum frame??
do correct my ignorance.
Thanks,
Colin
