A comparsion of expensive eyepiece and expensive tap.
Expensive Eyepiece
TeleVue 41mm Panoptic: S$950
The 41mm Panoptic eyepiece is a big brother to the 24mm Panoptic (largest 1.25" field). With its 46mm field stop, the 41mm Panoptic delivers the largest 2" field possible. An adjustable and removable screw-type top allows quick, comfortable eye positioning. The scalloped shape gives a positive grip.
Features:
Field of View: 68°
2.00" barrel size
Eye relief: 27mm
Weight: 2.1 lbs
Field Stop: 46mm
Expensive Tap
Gold Plated Tap: S$990
Control flow of water.
Features:
Gold Plated
If you got S$990, which item will you buy???
