Difference Between Monocular, Binoculars and Telescopes
soulfrost
Location: cookieland, dreamworld, North east Singapore .
Post by soulfrost »
what exactly is the difference between monoscope(or monocular?) , binoculars and telescopes?
i can tell their physical difference , but cant really explain when my friends ask me... so can someone explain this to me? thanks so much in advance! :lol:
Telescope is a general term. You can call a monocular and binoculars as telescope too.
Anyway, a monocular or spotting scope is general refer as a telescope that give a "correct" image. Most of the monocular's eyepiece cannot be change. A binoculars is basically mount two monocular together.
soulfrost
Post by soulfrost »
ok... then those long things called telescope can also be considered as monoscopes? thanks btw
AGMI
Post by AGMI »
depends. It is technically not possible for a newtonian reflector to give a "correct" image without the use of an erecting eyepiece
soulfrost
Post by soulfrost »
whats a newtonian?
AGMI
Post by AGMI »
A newtonian reflector is a Type of telescope that uses a mirror to focus light, unlike refractors which uses lenses.
heres some info on the different types of telescopes.
http://www.celestron.com/tb-2ref.htm
