Just wonder anyone had made a dew heater for refractor before?? I'm making one for my refractor using 8 x 5.6ohms resistor in series and will be using my "standard" battery pack (8 x 1.2V NiMH 1.8AH) to power it, so it'll give off total of around 2W of heat and will last around 8.5 hours.
Anyway, the problem I face is where to mount the resistors?? The dewshield is in the way and the lens cell is a huge chunk of metal. There are three places that I think it is suitable to mount the resistors:
1. On the lens cell behind the dewshield (my dewshield is removable) - the problem is that the lens cell is a huge chunk of metal and may conduct the heat away before it reach the lens cell,
2. On the lens cell inside the dewshield before the lens - I think the best place to mount it for maximum effectiveness, but will be very difficult to mount it firmly and do maintenance.
3. On the dewshield - easiest place to mount, but the heat may have difficulty to conduct to the lens, unless use a larger power.
Currently, I mount the resistors on the dewshield itself (easiest method) and cover the dewshield with a heat insulator to prevent the heat from escaping via the dewshield outer surface. I do a test indoor and it seem that the heat had difficulty to conduct to the lens...
Anyway, I hope that I don't need to increase the power of the heat, so that I don't need to carry any big battery and can last more than 5 - 6 hours. Anyone had better ideas???
