Blurness through 6x30mm finderscope
ovc17m
Post by ovc17m »
Was using my telescope last night for obing at my house, but realised i can't make out the stars thru my attached finderscope. The stars look diffuse and can only make out the brighter ones...
I checked and there's no dew or dust on my lens... what could be the possible reason?
Advise pls
~Clear skies don't occur every night, so date your BIG LENS out when the chance comes~
what finder do you have? some finders need to be focussed.
try turning head or eyepiece. if not, you may need to loosen the assmebly to focus....
kayheem
Post by kayheem »
Most of the skywatcher-type finderscopes have a fixed eyepiece. You will need to loosen the retaining ring around the objective assembly and screw/unscrew the assembly to focus.
Once it is in focus, tighten the retaining ring.
fizzy123
Post by fizzy123 »
I suspect that it is a "black out" in which u position ur eyes directly adjacent to the finder eyepiece. Neglecting the issue of Eye Relief, thus it causes some blurness. Or maybe you are squinting to hard into the finder, visual fatigue.
ovc17m
Post by ovc17m »
thanks everyone for the advices!.. will test it in my next obing... :)
