Excellent condition FUJINON FMT-SX 16 x 70 BINOCULARS
anguswholesale
Post by anguswholesale »
Incredible high magnification performing binoculars. Really needs to be tripod mounted for maximum effect. Built to U.S. military specifications, housings made of costly, lightweight aircraft grade aluminum alloys, precisely aligned and sealed to reduce the possibility of fungal growth and internal oxidation.
Dry nitrogen-purged, they are highly resistant to humidity and temperature extremes, impact and vibration. Special (Electron beam coatings) anti-reflection coatings (EBC) applied to each lens and prism surface delivers an outstanding 95% light transmission, resulting in incredibly bright images for outstanding vision in low light or night time conditions. Flattener lensese ensure even viewing throughout field of vision.
Selected premium optical glass delivers the ultimate in sharpness, accuracy and color correction with flat-field images that achieve the lowest distortion and astigmatism. Ultra long eye relief with fold-back rubber eyecups, make these binoculars ideal for those who wear eyeglasses. All utilize individual focus adjustments with a deep depth of field.
Speicifcation:
Model: Fujinon Polaris FMT-SX 16 X 70 Astronomical Binoculars (4 X THE LIGHT GATHERING POWER OF A 35MM LENSE)
Magnification: 16 X
Objective lens diameter: 70mm
Eye relief: 15.5mm
Apparent field of view: 4.4 deg
view at 1000m: 70m
Exit pupil (mm): 4.4
Relative Brightness: a stunning 19.1 !!! (95% LIGHT TRANSMISSION SUITABLE FOR ASTRONOMY)
Interpupillary distance: 56~74
Length 272mm
Max width: 248mm
Weight: 1.92KG
LOOKING FOR EXCHANGE FOR A SET OF 10 x 50 OR 7 X 50 fmtr-SX OR MTRC-SX OR ANY BINOCULARS ON OFFER.
CONDITION: EXCAHNGE (OF 10 X 50 OR 7 X 50)AND TOP UP WITH CASH
MEET UP AT BUKIT TIMAH COMMUNITY CENTRE FOR VIEWING.
HIGHEST BID SECURES. SELLING/EXCHANGING BECAUSE 16 X 70 TOO MUCH MAGNIFICATION FOR ME. REQUIRE A 7 X 50 OR 10 X 50 FOR OUTDOOR AND BOATING USE.
PLS CONTACT 90673103. THANK YOU
anguswholesale
asking $750. willing to exchange for 7 X 50 or 10 X 50 fujinon model with cahs top up. thank you and look forward to hearing from you all.
